Turning the pollution cap into a crankcase vent
- Powerstroke_fan
18 Nov 2012 20:30 - 19 Nov 2012 09:28
As most of you know iam in the process of my own little build. Anyway it was suggested that i might want to consider running another crankcase vent for more ventaltion. So i thought about turning my plugged off smog covers into a crankcase vent. I just thought about drilling some holes in each emmision port and allow it to run out hoses. Anyone did anything similar? or any tips or advice? Thanks, Eric
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 19 Nov 2012 09:28 by Powerstroke_fan.
- donthaveakawman
Re: Pollution cap vent???
18 Nov 2012 20:59
I think those have one way reed valves that let air into the exhaust. I wouldn't mess with them.
- Powerstroke_fan
18 Nov 2012 21:11
I already have them plugged off. right now i dont even have the reed valves in i did wonder if i could flip them over and use them?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Powerstroke_fan
19 Nov 2012 09:34
Maybe iam misunderstood. I have a j model head on my mk11 motor. I have already plugged the head to block off the emmission ports. It was sugested that i need more crankcase vent. I still am running stock crankcase vent on the top of the crankcase.But i wanted to drill out the valve cover inside the old emmission housing and possibly flip over the reed valves so the air can be pushed out the cover and thru the emmission port on the valve cover. Turning it into a crankcase vent for extra ventaltion. I just worried about oil get pushed out there. And wasnt sure if anyone else has done this. Or if anyone had a any tips. Thanks, Eric
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Nebr_Rex
19 Nov 2012 11:50
I don't see why not.
Like you said, oil getting pushed out by the spinning cam.
Maybe some sort of trap with a screen.
Or would it be more effective on the cam chain tunnel?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- LarryC
19 Nov 2012 12:12 - 19 Nov 2012 12:22Powerstroke_fan wrote: Maybe iam misunderstood. I have a j model head on my mk11 motor. I have already plugged the head to block off the emmission ports. It was sugested that i need more crankcase vent. I still am running stock crankcase vent on the top of the crankcase.But i wanted to drill out the valve cover inside the old emmission housing and possibly flip over the reed valves so the air can be pushed out the cover and thru the emmission port on the valve cover. Turning it into a crankcase vent for extra ventaltion. I just worried about oil get pushed out there. And wasnt sure if anyone else has done this. Or if anyone had a any tips. Thanks, Eric
The factory did it already. All the stock emissions components will work. The only difference is you're not allowing the crank case gasses to be sent to the air box first. Hook it up directly to the crank case vent instead. You would want some baffeling in place to prevent sucking oil into the exhaust system. The stock airbox prevented that.
The OEM version allowed the gasses to be pulled into the carburetors where they partially diluted the mixture. Didn't really hurt much of anything.
The exhaust system sets up a very strong depression at and for a short time after TDC on overlap. It's actually a stronger depression than the piston can create on it's downward stroke.
Larry C.
Last edit: 19 Nov 2012 12:22 by LarryC.
- Nasty610
Re: Turning the pollution cap into a crankcase vent
19 Nov 2012 14:39
When I was into boosted cars a buddy told me this was done quite frequently on Toyota Supra's. They just reroute the crankcase vent straight to the exhaust after the turbo. There were a lot of guys that claimed to gain hp but I never saw a dyno graph to prove it. I don't remember if they did anything to stop oil from being sucked into the exhaust but you can always get on a Toyota forum and do a search.
19 Nov 2012 15:01
Dont have a smog cover , but on my 78 1000 I took a 90 degree half inch fitting and welded it to the cam cover . Its locsted on the right side of the cam chain tower pointed out the back. My hose runs to the swing arm chain guard to a point behind the front of the rear tire . very little oil comes to this point but if it does it dumps onto the drive chain. Or do the same and run it into a catch can ( beer can ). I did mine to help control excess crankcase pressures as my motor runs lots of boost.
- zed1015
19 Nov 2012 15:53Powerstroke_fan wrote: As most of you know iam in the process of my own little build. Anyway it was suggested that i might want to consider running another crankcase vent for more ventaltion. So i thought about turning my plugged off smog covers into a crankcase vent. I just thought about drilling some holes in each emmision port and allow it to run out hoses. Anyone did anything similar? or any tips or advice? Thanks, Eric
I have done a few.
I block up the ports in the cover that usually align with the ones in the head then open up some holes in the bottom of the emission chambers directly into the head.
These are positioned right above the camcaps so they are shielded from any direct oil splash.
I remove the reed valves and fill the empty chamber with some stainless gauze to catch the oil mist.
You can then run some hose from the cover to a catch tank, vent fiter or whatever.
I have a MK2 cover i have just done if you need pics.
19 Nov 2012 18:07
uh er,yes sir could we see the pics
- lushbaugh
- everybodys a pro......
19 Nov 2012 18:14
i too need pics as im trying to figure out how to vent mine that are stock except ran to eachother to the rear and to a catch can.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
