  • Page:
  • 1
  • 2
83 KZ750 wont start! 10 Sep 2012 11:04 #547809
  • tybo88
  • tybo88's Avatar Topic Author
  • Visitor
Hey guys and gals looking for some help as i have run out of ideas i have an 83 kz750 that i cannot get to start ive cleaned the carbs got a fresh battery checked the timing to the best of my ability not sure if i did it right ive got spark compression seems ok main problem is i have the k&n filters for each of the four carbs but am missing one but the bike started up and ran without it now the starter turns every once in awhile there will be a big backfire out of the exhaust and smaller "backfires" more like poofs of air that come out of the carbs what can i do to get this thing runnig!!!!
Thanks everyone in advance.
83 KZ750 wont start! 10 Sep 2012 11:20 #547813
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
I suspect bad or discharged battery. These bikes need a steady source of electrical power to run correctly. A low battery will produce weak spark, and not have enough left to crank the engine over.
Get a motrcycle rated charger(no more than 1.25 amps an hour)and fully charge the battery. Also all the large cables going to the battery and the engine mounting terminal must be clean and tight for maximum current transfer.
How's the spark look,weak and orange in color? It should be a hot,fat blue spark.
83 KZ750 wont start! 10 Sep 2012 11:36 #547815
  • tybo88
  • Visitor
It has a nice blue spark I thought the battery would be it too but I've jumped it so it's cranking ok it seems a nice fast turn could I bump start it to see if that the problem? It does seem like it floods when I try but it won't start even with a shot of starter fluid
83 KZ750 wont start! 10 Sep 2012 12:24 #547817
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
The 83 should have an electronic ignition and the timing cannot be set. Did you take anything apart, like the cams to asjust valves are the ingition advancer?
83 KZ750 wont start! 10 Sep 2012 13:40 #547827
  • tybo88
  • Visitor
I did not is it something i can do myself? and how would i do it?
and yes it is an electric ignition
83 KZ750 wont start! 10 Sep 2012 13:47 #547830
  • baldy110
  • baldy110's Avatar
Take all the pod filters off and try spraying starting fuild into the carb throats. If it fires off then you know you have a carb problem, probably still dirty. If it does not fire off then you have an ignition problem.
83 KZ750 wont start! 10 Sep 2012 15:14 #547841
  • Thank you received: 2098
Be sure the coils are connected to the correct spark plugs.
Good Fortune! :)
83 KZ750 wont start! 10 Sep 2012 15:57 #547845
  • tybo88
  • Visitor
Yep they're all hooked up right
83 KZ750 wont start! 10 Sep 2012 15:59 #547846
  • tybo88
  • Visitor
Also tried with the starter fluid that didn't do anything either
83 KZ750 wont start! 10 Sep 2012 16:10 #547848
tybo88 wrote: ...83 kz750...cannot get to start...checked the timing to the best of my ability not sure if i did it right ive got spark compression seems ok...every once in awhile there will be a big backfire out of the exhaust and smaller "backfires" more like poofs of air that come out of the carbs....
Am thinking the ignition timing is permanently set by the factory and not intended for adjustment by owner.
Such ignition timing controls when the spark plugs fire in relation to position of the crankshaft.
Cam timing controls opening and closing of the valves in relation to position of the crankshaft.
Was any "adjustment" attempted or made to either type of timing?
Was the timing advancer removed and replaced?
Or was the ignition rotor removed and replaced (which might have been replaced 180 degrees off)?
Good Fortune! :)
83 KZ750 wont start! 10 Sep 2012 16:17 #547849
Viewing through the timing inspection window, the F mark for 1&4 should align with the case mark as the rotor pointer passes the left-hand (nine o'clock) pick-up module, which is when the 1&4 pistons are just before reaching top dead center.
If the rotor was removed and replaced (for whatever reason), it might have been incorrectly reinstalled 180 degrees wrong.
Good Fortune! :)
Last edit: by Patton.
83 KZ750 wont start! 10 Sep 2012 16:27 #547850
  • tybo88
  • Visitor
when the line by the f mark is all the way at the top the pointer is directly in line with the little metal peice on the pick up i was just informed that the plugs maybe fouled and to try new plugs any way to test if they are fouled? and no the plates werent moved or replaced as far as i know
  • Page:
  • 1
  • 2
