  • Page:
  • 1
csr1000 ignitor 19 Jun 2010 17:19 #376865
  • kwak650
  • kwak650's Avatar Topic Author
  • Thank you received: 0
My csr1000 is having issues with the ignitor box,it seems to be shorted to ground internally.I have a dyna 111 box from a 650 just wondering is there anyway to wire it to my csr1000.Thanks
csr1000 ignitor 19 Jun 2010 18:14 #376876
  • otakar
  • otakar's Avatar
  • Thank you received: 29
Just get another igniter on eBay. They are quite common. I have 4 spare units for mine. You can pick them up for anywhere between $25 and $50. The Dyna is a deferent system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
csr1000 ignitor 19 Jun 2010 18:17 #376878
  • otakar
  • otakar's Avatar
If you want a really good igniter, build one yourself from two GM modules. There is a design by one of our members here and it rocks.
www.kzrider.com/archive/viewthread.php?tid=27518
This link will not work right you will have to coppy and paste it.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: by otakar.
csr1000 ignitor 20 Jun 2010 07:11 #376983
  • JMKZHI
  • JMKZHI's Avatar
  • Thank you received: 48
From the cross-reference in the diagrams at Kawasaki.com:
KZ1000-M1 (CSR) (1981)
21119-1041 Igniter
Model (26):
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1000-M2 (CSR) (1982)
KZ1000-P1 (Police 1000) (1982)
KZ1000-P2 (Police 1000) (1983)
KZ1000-P3 (Police 1000) (1984)
KZ1000-P4 (Police 1000) (1985)
KZ1000-P5 (Police 1000) (1986)
KZ1000-P6 (Police 1000) (1987)
KZ1000-P7 (Police 1000) (1988)
KZ1000-P8 (Police 1000) (1989)
KZ1000-P9 (Police 1000) (1990)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1000-R2 (Eddie Lawson Replica) (1983)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-B1 (GPz) (1981)
KZ1100-B2 (GPz) (1982)
KZ1100-D1 (Spectre) (1982)
KZ1100-D2 (Spectre) (1983)
KZ1100-L1 (LTD Shaft) (1983)
The supersession shows these part numbers:
21119-1356 Igniter Newer
21119-1041 Igniter
21119-1030 Igniter Older
csr1000 ignitor 20 Jun 2010 07:56 #376993
  • kwak650
Thanks for the crossreference info I should be able to find something to match.If not I might try to build one I am hearing alot of good things about the GM HEI mock up.
---- 20 Jun 2010 08:02 #376995
  • H1Vindicator
  • H1Vindicator's Avatar
  • Thank you received: 45
Last edit: by H1Vindicator.
csr1000 ignitor 20 Jun 2010 11:10 #377046
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
  • Thank you received: 28
H1Vindicator wrote:
The downside to buying used electrical parts is that you never really know if it's any good until you install it on the bike.
B-B-B - BINGO! :laugh: :laugh:
Soooo true!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
csr1000 ignitor 20 Jun 2010 13:23 #377075
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
If you plan on doing the GM electronic ignition module design by Loudhvx, I've got cross index part numbers for other manufacturers:
GM HEI Ignition Modules (4 Pin)
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
csr1000 ignitor 20 Jun 2010 19:33 #377140
  • otakar
  • otakar's Avatar
I've been very lucky. All three that I have bought turned out good. Actually the failure rate on these units is very low, unless you mismatch a set of wrong aftermarket coils which are less than 2.2 Ohms. We have had one member here that did have a problem with one but it is a very rare problem.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Page:
  • 1
