I'm baffled, now
  • loudhvx
  • loudhvx's Avatar Topic Author
I'm baffled, now
13 Aug 2009 09:55 - 21 Nov 2019 08:10
#313649
Making a Kerker knock-off baffle. I'm, making it similar to a Kerker K series muffler. The canister is a Kerker or Kerker knock off, but it is beat up from years of track duty. I got it with no baffle, so here it goes. (Also, just starting to learn how to weld with flux core MIG, man is it messy... wish I had my Oxy-A rig... slower, but neater.)
First the screen. I bought it at Menards. It's expensive, so if anyone wants some, I have most of it still left over I can sell.
It forms really easily around a pipe in a vice.
Attachment RolledScreen.jpg not found
Last edit: 21 Nov 2019 08:10 by loudhvx.
  • loudhvx
Re: I'm baffled, now
13 Aug 2009 09:57 - 21 Nov 2019 08:13
#313651
Next, found some old rollers at work that were close to the right diameter for pipe stock.
Attachment PipeStock.jpg not found
Last edit: 21 Nov 2019 08:13 by loudhvx.
  • loudhvx
13 Aug 2009 09:58 - 21 Nov 2019 08:13
#313654
I made a nozzle out of the end of the pipe.
Attachment NozzleCutout.jpg not found
  • loudhvx
13 Aug 2009 09:59 - 21 Nov 2019 08:15
#313655
Cut and weld the nozzle to the screen.
Attachment NozzleWelded.jpg not found
Last edit: 21 Nov 2019 08:15 by loudhvx.
  • loudhvx
13 Aug 2009 10:01 - 21 Nov 2019 08:16
#313656
Welded on a tailpipe to the nozzle outlet.
Attachment NozzleTailPipe.jpg not found
Last edit: 21 Nov 2019 08:16 by loudhvx.
  • irishwill
  • irishwill's Avatar
13 Aug 2009 10:01
#313657
KEWL!!!
  • loudhvx
13 Aug 2009 10:02 - 21 Nov 2019 08:20
#313658
The tailpipe will fit into the center of the end-cap doughnut.
Attachment TailPipeIntoCap.jpg not found
Last edit: 21 Nov 2019 08:20 by loudhvx.
  • loudhvx
13 Aug 2009 10:04 - 21 Nov 2019 08:28
#313659
EDIT: I originally went with a tube within a tube design for the exit to make the baffle more stable. But it was heavy, so I removed it and later just put a stop ring on the pipe to stop the baffle from sliding backward. The following three photos are of the first design.
Attachment SupportSleeve.jpg not found
Last edit: 21 Nov 2019 08:28 by loudhvx.
  • loudhvx
13 Aug 2009 10:05 - 21 Nov 2019 08:29
#313662
Attachment SupportSleeveWelded1.jpg not found
Last edit: 21 Nov 2019 08:29 by loudhvx.
  • loudhvx
13 Aug 2009 10:05 - 21 Nov 2019 08:30
#313663
Another shot
Attachment SupportSleeveWelded2.jpg not found
Last edit: 21 Nov 2019 08:30 by loudhvx.
  • loudhvx
13 Aug 2009 10:08 - 21 Nov 2019 08:31
#313664
Now the other end is rougher. The canister is mangled, so the entrance to the baffle has to have a wierd shape to it. If I get a new canister somewhere, I'll have to cut off the entrance and weld on a nicer one.
Attachment EntranceTaper.jpg not found
Last edit: 21 Nov 2019 08:31 by loudhvx.
  • loudhvx
13 Aug 2009 10:09 - 21 Nov 2019 08:47
#313667
I was going to weld the slits, but then realized brazing would do a better job here. The MIG tends to burn open slits into large holes.
EDIT: I'd probably weld it now, having had more time with the mig.
Attachment EntranceBrazed.jpg not found
Last edit: 21 Nov 2019 08:47 by loudhvx.
