yet another KZ1000 streetfighter build
- chonus
Re: yet another KZ1000 streetfighter build
14 Nov 2012 12:50
hahaha I just noticed Its in the kitchen too.. Love it!!
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- jarrad
14 Nov 2012 18:30 - 14 Nov 2012 18:31
thanks mate, i rekon they will look fairly similar when done.
its a 09' R1 swinger, so that's the way it sits, i chose it coz it had the underbrace and the cut out in one side so i can do an undertail exhaust....
it also has reversed linkage, if you look at the pic below you will notice the dogbone
bolts to the swingarm not the frame.
the only problem i have had so far is having to make a swingarm piviot bolt and bushes, but thats only because in using a shaft drive frame as they are a lot wider and give better chain clerance on the frame.
the triples are off a 05' Z1000, the forks are the same size!
"IF EVERYONE HAS ONE, I DONT WANT ONE"
79 z1000st BUILD:
www.streetfighters.com.au/for...-OLDSKOOL-quot
R6 build:
www.customfighters.com/forums...ad.php?t=53108
KDX build:
www.dirtrider.net/forums3/sho...d.php?t=166143
79 z1000st BUILD:
R6 build:
KDX build:
Last edit: 14 Nov 2012 18:31 by jarrad.
The following user(s) said Thank You: fizzer_$tfighter
- chonus
16 Nov 2012 20:18
wow that's awesome may have to consider running those triples. where did you find those spoked rims? i think id trade an arm for a pair of those!!
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- jarrad
16 Nov 2012 20:51
haha you will need an arm and a leg mate....... they are fuken hard to find!!! i searched every day for about 3 months until i found some. my Black set owe me about $1500 now after powdercoating
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- chonus
07 Dec 2012 20:54
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
07 Dec 2012 21:58 - 07 Dec 2012 22:02When new, a few Kawasaki models had a built-in security cable residing inside the frame, which was pulled out when needed to lock the bike to a nearby post or whatever.
Am vaguely recalling a ring on the cable end that remained accessible when the cable wasn't deployed.
It usually didn't take very long until the cable rusted stuck inside the frame and became unusable, and so nasty that nobody wanted to use it anyhow.
If it's not that, I don't know what it is. And if it is that, nobody ever needed it.:lol:
Last edit: 07 Dec 2012 22:02 by Patton.
- jarrad
08 Dec 2012 00:10
um yep what he said....
i have never seen that on an Australian or New Zealand modle.
cut it off mate!
cut it off mate!
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
08 Dec 2012 02:11
There were probably other Kawasaki models with the provision for the built-in security cable.
It's only barely visible in the brochures shown in the foregoing posts.
I believe -- but not positive -- that it's included on '81, '82 and '83 J models.
