Let's Get This S*** Started!
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
Re: Let's Get This S*** Started!
23 Nov 2012 18:27
hey, thanks for the replies guys. I just read the manual and realized it will be easy to install the cams, check clearances, pull the cams back out, change shims as necessary, then install the head, cams, time cams etc....oh wait, will I be able to turn the cams with gears without using the crank and timing chain?
- z1kzonly
23 Nov 2012 18:47
Whatever you do, Just Make Sure You Do 1 Cam In The Head At A Time!
no bent valves!
And Push Down On The High Side Of The Cam When You Start The Cap Bolts!
no stripped cap bolt threads!
no bent valves!
- seanbarney41
