Author: Subject: KZ550 LTD - Clutch Cable Replace - Basic Steps
JGailor
Junior Member
[*] posted on 6-10-2003 at 09:17
Can anyone give me the basic steps for replacing the clutch cable on this bike. I don't yet have a service manual, and the clymer book isn't worth a damn when it comes to this operation.
Just an outline of what comes first, second, etc.
Thanks
lifeliberty
[*] posted on 6-10-2003 at 09:31
i used the clymer manual and it worked out fine for me. basically, first I removed the cable from the handlebar, remember how it was routed. then remove the countershaft cover, and remove the cable. here is an article http://kzrider.com/clutch_cable_tip.shtml
JGailor
Junior Member
[*] posted on 6-10-2003 at 09:44
Can you tell me, did you have to drain the oil for it?
A friend changed his (different model bike) and had to drain the oil to do so.
SkynyrdMan
[*] posted on 6-10-2003 at 09:48
I don't think you need to drain the oil in order to just replace the cable...just remove the sprocket cover to get to the cable...no oil in there
clawson
[*] posted on 6-10-2003 at 10:44
Don't pull the clutch pushrod out when you replace the cable, or you *will* be draining oil...right out the pushrod hole ;)
cl
1976 KZ400 D3
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member clawson's Aim
[PHP: 70.7% - SQL: 29.3%]
